Ever since having the kiddo in daycare I’ve been driving Melissa’s old XJ. It has v8 XJ springs under the front I got from Kirby many moons ago with some sort of spacer on top and a couple of weeks ago I finally put longer shackles in the rear to keep the tires from rubbing the body every time I hit a bump. Friday I built a set of adjustable uppers to go with a set of lowers I’ve had around for years. Tested them yesterday and will finish burning them together and I will throw them on our powdercoat line sometime this week. Had some driveline vibes from lifting the rear and made a drop out of 1x2 that fixed that issue for the time being.
Joints are from Barnes. The bent part may be from them too I forget. Way overkill with 1.5x.25 DOM but it was the first stick I found on my rack at work so.
