So, I was spooling the winch line on my TJ and I figured while I had the tree savers hooked up I would respool the JK winch line. When I unspooled it the bottom layer of line and the winch drum was corroded. Its an aluminum drum, but it looked like it had been at the bottom of the ocean. Anyone ever seen this? I searched online and there were 3 other instances of people mentioning it, but no solution as to how to keep it from happening. I called Warn and they had never heard of it. I know there are a number of products you can use on aluminum to keep it from oxidizing, but I'm not sure if they are safe for synthetic line. Any thoughts?
