1946 Willy's CJ2a Build
Traded a rifle for a 1946 CJ2a.
I was surprised how un-bubba'd the jeep was. The last time is was registered was 1992.
Worse thing besides rust on it was the white marine upholstery on the seat frames, but they are in the garbage now.
My daughter has claimed it as hers
I believe the Jeep was restored or attempted to be restored in the late 80's. The original color is Harvard Red, but it was plastered with green, on the body, tubs, frame and rims. And a generous job of rubber truck bed coating was applied over the frame, and body. It is now flaking away but it did seem to help some in the rust area. The rear bed has zero Rust holes in it. Front floors not so much. The passenger side was repaired at some pioint but poorly done. The floor under the gas tank was repaired with a piece of sheetmetal and an floor drip pan screwed to the remnants of a floor.
My plans are to keep it mostly original with the exception of putting disc brakes up front and add a dual resovior Master cylinder. The rear brakes are going to stay the original 9 inchers.
