This past week the whole family loaded up in the jeep with trailer in tow and headed off to Pigeon Forge, TN for spring break. The jeep was full and pulling the trailer at highway speeds all the way up 26 and 40, which I have done before. Once we got to the cabin we spent alot of time driving here and there to points of interest and most of the roads were paved twisty mountain roads. The last day we went up to Wind rock off road park and did some moderate trails. The return trip was a tad different because we had to drop my daughter off with her mom and we met at Rocky Mt, NC (half way for both of us) so we drove 40 east and then hauled butt home down 95.
Ok so I bored you with my trip routes because I wanted to make the point that I spent alot of seat time in the jeep this past week. I had few issues but , the biggest seems to be that my springs are not holding up their end of the bargin. I currently run 3 year old OME 2" ZJ V8 springs in the front and OME 2" LJ springs in the rear. I run both stock sway bars on road and the rear off road. I also run airlift bags in the rear for the added weight of the full trailer. Now on this trip even with tires aired up to 32psi (35psi max) air in the airbags (rear was hitting bump stops around town) the suspension was mush. Every little bit of wind or curve in the road would cause the body to sway and roll. The kids (young teenagers) had to take sea sick pills just keep from getting ill
On the trail with the front sway bar disconnected the body lean and roll was excessive.
Now I have added steal body sides (75-100lbs for both?) and stretched the rear suspension. Other than that nothing has really changed. The kids have gotten older but, not dramatically heavier, the trailer was a light load for this trip, just suitcases and a cooler. I think I need to run a heavier or better spring? I have found some good write ups but, want to hear what your thoughts are. What 2" springs are you running out there?
